It is currently Wed Aug 13, 2025 8:51 am
PostPosted: Mon Nov 16, 2015 6:12 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
As the picture show, a bit of grain blow out while routing for bindings.
My thought is to carve the damage out, like this, and glue in a sliver of wood, level, and re-route.Image
Any other suggestions would be greatly appreciated. The damage is on the treble side, front lower bout, so it will not show too much. Thanks!
Alex
 Post subject: Re: oops advice
PostPosted: Mon Nov 16, 2015 6:15 pm
Make your bindings a bit taller and add purflings and rout the damage off.
These users thanked the author meddlingfool for the post: Alex Kleon (Mon Nov 16, 2015 7:45 pm)
PostPosted: Mon Nov 16, 2015 6:38 pm
First name: Alex
Last Name: Kleon
City: Whitby
The binding and purfling is at 1/4" and the damage would need to be routed to 11/32". That's a bit deeper than I'd like to go, Ed.
This is a first guitar, and I'm not having visions of grandeur. I'm sure there will be other blemishes along the way. I'm pretty good at "Dutchman" repairs.
Alex
PostPosted: Mon Nov 16, 2015 6:46 pm
City: Tyler
If you don't want to go deeper, the only option I know of is to shim in a piece. If you can find the blown out chunk, see if it works. I have had luck with that. I personally haven't had great luck using a separate piece. Otherwise, if it looks bad when all put back in, do a burst that shades the sides, and go dark over that spot.
These users thanked the author Glen H for the post: Alex Kleon (Mon Nov 16, 2015 7:45 pm)
PostPosted: Mon Nov 16, 2015 7:19 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
If you have not vacuumed that piece is around. I have gotten on my hands and knees until I have found the bit of blown out wood. When it comes out that way the piece is around an most likely intact
These users thanked the author johnparchem for the post: Alex Kleon (Mon Nov 16, 2015 7:45 pm)
PostPosted: Mon Nov 16, 2015 7:24 pm
Which is why vacuuming after each operation that went well is so advantageous. Narrows down the splinters to sort through...
These users thanked the author meddlingfool for the post (total 2): Imbler (Tue Nov 17, 2015 10:57 pm) • Alex Kleon (Mon Nov 16, 2015 7:45 pm)
PostPosted: Mon Nov 16, 2015 7:35 pm
First name: Alex
Last Name: Kleon
City: Whitby
Cleaned the bench before routing, so unless it shot into the corner of the shop, it should still be there.
I made a copy of your binding jig, Ed, and it works great! I'm using a down spiral bit and a bearing guide instead of the rabbeting bits.
Another glass of wine and some more olives, and I'll start looking for the splinter!
Alex
PostPosted: Mon Nov 16, 2015 8:42 pm
First name: Tom
Last Name: West
State: Nova Scotia
Somogyi suggest when this happens to turn it into a decorative feature. Maybe a half diamond shape in ebony. Maybe a matching one on the other side. Lemons into lemonade. I tend to agree with the others re the blown out piece.................if you can find it. Good luck, keep thinking it through before acting. All will work out.
Tom
These users thanked the author Tom West for the post: Alex Kleon (Tue Nov 17, 2015 6:46 am)
PostPosted: Mon Nov 16, 2015 9:29 pm
Good luck on your hunt! Been there too many times:)
My jig is an iteration of the Ribecke jig, I believe. I like the LMI bits, cause we have a router for each cut and just swap routers. Whomever invents a system like that with a downshear gets some of my money though...
These users thanked the author meddlingfool for the post: Alex Kleon (Tue Nov 17, 2015 6:47 am)
PostPosted: Mon Nov 16, 2015 9:46 pm
First name: Danny
Last Name: Vincent
Put the close up glasses on and find that splinter! Looking good. Going to look awesome. I love the Wenge. If you can't find the piece, wood dust and CA on the treble side of your first guitar would hardly be noticed but I KNOW you could splice a sliver in.
These users thanked the author DannyV for the post: Alex Kleon (Tue Nov 17, 2015 6:47 am)
PostPosted: Mon Nov 16, 2015 10:00 pm
That sucks Alex.
Get some hose (stockings) or thin tee shirt and cover the vacuum nozzle and start picking up the dust/splinters around the area you were working... when the cloth is clogged, turn the vacuum off over a small pan or container, this should reduce your hunting time.
These users thanked the author Rod True for the post (total 2): Alex Kleon (Tue Nov 17, 2015 6:47 am) • Pmaj7 (Tue Nov 17, 2015 3:02 am)
PostPosted: Mon Nov 16, 2015 10:10 pm
First name: Trevor
Last Name: Gore
City: Sydney
If you can't find the piece...
Did you thin the edges of the soundboard?
If not, you may be able to find a millimetre or so there, then rout for deeper bindings, but 1mm less deep than they might have been. You only need to get as deep into the chip as to where the bevel outward starts. A good epoxy grain fill will pretty well hide the rest.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: Alex Kleon (Tue Nov 17, 2015 6:48 am)
PostPosted: Mon Nov 16, 2015 10:36 pm
First name: Alex
Last Name: Kleon
City: Whitby
Sifted through all the shavings on the bench top and found some splinters that might have been parts of the missing piece, but nothing that I could fit together.
I cleaned up the damaged area, and managed to get two clamps on a 5/8" patch. Tomorrow will either be a triumph or a do over! I'm not at all upset about this. Stuff happens all the time. If I had take a chunk that size out of my thumb, it would be a different story!
This guitar making stuff is fun! [:Y:]
Alex
PostPosted: Mon Nov 16, 2015 10:46 pm
First name: Alex
Last Name: Kleon
City: Whitby
Here's how did the bearing guide, Ed. Like most of my jigs, the idea was borrowed from someone else.
The fine adjust is a carriage bolt through an angle bracket, into a barrel nut.
Alex
PostPosted: Tue Nov 17, 2015 12:56 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Yeah I would look for the piece. I think matching a piece to a carved out area like you mentioned would be more noticeable.
Sent from my SGH-T599 using Tapatalk
Another day, another dollar.
These users thanked the author Shaw for the post: Alex Kleon (Tue Nov 17, 2015 6:48 am)
PostPosted: Tue Nov 17, 2015 1:39 am
Last Name: Kincheloe
Does the guitar have a cutaway? If not, you could turn it into a lefty with a micro armrest bevel :)
These users thanked the author DennisK for the post: Alex Kleon (Tue Nov 17, 2015 6:48 am)
PostPosted: Tue Nov 17, 2015 6:51 am
First name: Alex
Last Name: Kleon
City: Whitby
[clap] Thanks, Dennis! I would have been sadly disappointed if someone hadn't suggested that one! laughing6-hehe
Alex
PostPosted: Tue Nov 17, 2015 9:10 am
Simplest, putty the area with good dyeable putty, dye the area, apply some Weldon 16, rub into the putty, then sand flat and dye the whole back and sides.
These users thanked the author Haans for the post: Alex Kleon (Tue Nov 17, 2015 11:25 am)
PostPosted: Tue Nov 17, 2015 10:51 am
I have successfully used the method described in your initial thoughts -- if you have a matching or similar piece of wood its possible to make a near invisible repair. Glue the splice in with Elmer's do not use CA pay attention to the grain orientation -- the trick is scratch in some grain lines crossing the glue joint then use very fine marker or color pencil to lay in the grain color. Go a little beyond the actual repaired area with the fake grain -- I think you will be surprised how natural this will end up looking.
Ken Cierp
These users thanked the author kencierp for the post: Alex Kleon (Tue Nov 17, 2015 11:25 am)
PostPosted: Tue Nov 17, 2015 12:26 pm
First name: Alex
Last Name: Kleon
City: Whitby
Once the patch was glued and left to completely dry, I sanded it flush with 240 paper on the back of a chisel along with a couple of thicknesses of masking tape so that only the high spot of the patch gets sanded to the same curvature as the side.Image
Thanks for all the replies and suggestions. As usual, you folks are the best!
Alex
PostPosted: Tue Nov 17, 2015 1:14 pm
First name: Wendy
Last Name: W
State: Arizona
Nice job!
PostPosted: Tue Nov 17, 2015 4:12 pm
Had a similar thing on my build..the router chuck slipped and made a massive mess of my binding channel, taking out a large chunk for a 1/5th of the guitar. .
Fixed using extra beading ..turned out ok in the end.. stressful time though
Good repair there
These users thanked the author cablepuller1 for the post: Alex Kleon (Tue Nov 17, 2015 6:19 pm)
PostPosted: Tue Nov 17, 2015 4:54 pm
First name: Tom
Last Name: West
State: Nova Scotia
What blowout......................????
Nice recovery..! Alex
Looks like you were doing conventional routing at full depth when you had the blow out. I like to go in about .020" to .030" for a primary cut. In my mind less chance of blowout at full depth. Also I like to climb mill, also less chance of blowout. Trevor Gore points this out in his book. When you climb mill you can go all around the guitar in one direction. Thanks Trevor.
Tom
These users thanked the author Tom West for the post: Alex Kleon (Tue Nov 17, 2015 6:19 pm)
PostPosted: Tue Nov 17, 2015 6:30 pm
First name: Alex
Last Name: Kleon
City: Whitby
Thanks, Tom! I did conventional route on the four bout areas, and then a 360 climb cut. I'd have to say I should have used a bit more caution than I did. This wood seems to be on the fragile side. I did three crack repairs on the sides early on, although maybe I was a little ham handed.
When it is ready for pore fill, I'll be doing what Ken suggested - etching some grain lines, and colouring them. I've done that in the past where I had to repair furniture that I'd built for customers. I would always tell them, but they had to find it themselves!
Alex
PostPosted: Tue Nov 17, 2015 7:08 pm
First name: D
Last Name: S
Alex, you showed that blowout who it's daddy is!
Nice-un.
Dan
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Alex Kleon (Tue Nov 17, 2015 7:17 pm)
Users browsing this forum: bcombs510, dofthesea, rbuddy and 12 guests
